-   -   350 Mag cooling issues HELP (https://www.offshoreonly.com/forums/general-q/298464-350-mag-cooling-issues-help.html)
LotusElise88 06-19-2013 11:02 PM
I just got a 2002 Donzi 28 ZX with twin 350 Mags. One of the engines were overheating so I pulled the impeller and it was shot I replaced it and engine was still over heating I know there in nothing stuck in the system after the impeller because I have a T with fresh water flush out and the engine runs great on the hose so it have to be somewhere from the out drive to the impeller but I haven't seen anything about this maybe someone can help
Thank You
LotusElise88 06-19-2013 11:07 PM
Also it ran for about 5 to 10 mins before over heating
dodgezilla04 06-19-2013 11:43 PM
I know on bravo drives there is a fitting through the transom that corrodes and ends up with a reduced ID. Causes overheating at high rpm due to the lack of water. They're fine on the hose
Port Monster 06-20-2013 02:55 AM
Corroded bravo one drive hoses are what caused mine to overheat. The corrosion occurs where the hose comes through the transom assembly.
looseconnection 06-20-2013 06:16 AM
On the hose you have no load on the engine and heat build up is less...this is assuming you have not ran with muffs on the hose. Run with muffs on hose to to verify that is where the problem is. Those hoses can fail and collapse and not leak since they are under suction and not pressure. Thats why it is a different type of hose with a steel spiral to keep it open, the internal lining can sag reducing water flow.
Expensive Date 06-20-2013 07:31 AM
What everyone said plus check your actual pump and pump plates for wear if you have the new style with stainless steel wear plate change it I have head pumps that were worn that do not want to do build pressure
LotusElise88 06-20-2013 12:57 PM
Ok so if I pull the outdrive today will I have access to the hose? What part do I need to get to change it? And it's overheats in N In water so there's no load
Port Monster 06-20-2013 01:54 PM
It isn't that easy. If you think that is what it is I would pull the plastic piece off inside of the transom. You will see the raw water hose is attached to a 45 degree fitting inside. That fitting is held on by two bolts. Pull that and double check if it is clogged. You will see white corrosion and the hose would be collapsed.
28Eliminator 06-20-2013 02:42 PM
If you just changed the impellor, the housing could still be badly worn causing the low water flow. Also verify the hoses were put back on the correct ports on the pump. I still get burned by this once in a while.
LotusElise88 06-20-2013 06:57 PM
Ok so I pulled the elbow off the it was almost sealed off maybe a pencil size hole I'm cleaning it out now seems to be only in the end. I hope so because I heard you have to pull the engine to change it.
masi242 06-20-2013 08:07 PM
Did this last year, but mine was on a 454/alpha the tube was clogged with crap it used to overheat on long idles. Mine has been fine, run it until you have another problem.
Port Monster 06-20-2013 08:26 PM
In my case - and I think in a lot of cases - the corrosion collapses the hose down into itself and that creates the clog. Not sure you will be able to sucessfully clean it out. Just be careful with it!
LotusElise88 06-20-2013 09:35 PM
well i was using a die bit to sand it out and it broke off now what lol and it went inside i have about a 1/2 in hole should i try with a bigger bit to go the rest of the way and maybe i can flush both of them out or should i take the drive off. will i be able to take the rubber hose off
LotusElise88 06-20-2013 09:38 PM
i didnt see any collapsed hoses theres an elbow witch i removed and a rubber hose behind the drive looks good
