Alternatives to Procharger intercooler
I have 350 mags in my boat with procharger set-ups on each engine. I have a small leak in each intercooler so I have to replace them. The issue I'm having is that procharger intercoolers when used in salt (I leave mine in a weekend at a time) will supposedly rust out in a year and they cost $1250 each to replace. I was wondering if anyone has run the prochargers at a lower (3.5 psi) without intercoolers? Alternatively has anyone used and alternate intercooling method that will withstand salt water running longer term? Is anyone running air to air? I really like the way the boat performs with the chargers and the fuel efficiency they provide with a lots of power on tap. I'm not interested in building 383's or other performance small blocks as I really like the idea of being able to replace an engine fairly inexpensively should one fail. Thank you for any info you might have.
What about a water/meth injection setup? I run one on my turbocharged LS with no intercooler and it works great.
I was wondering if that might work. At what pressure would you kick it in? What size nozzle would be appropriate? I would think a large tank would be needed.
call snow performance,they can help you with the proper setup.
Your going to need a large tank for that as a boat is under load all the time unlike a car that doesn't have to be in boost at all cruising. Do a search for killer chiller setups.
is there a way to flush them when you get back to dock after running?
Originally Posted by mike tkach
(Post 3946298)
Originally Posted by zx6rr33
(Post 3946227)
http://www.alcohol-injection.com/en/ Depending on how hard you're running for how long, I'd think that a 3 gallon tank would be plenty for a day on the water. I always run -20* windshield washer fluid which has about 30% meth 70% water. |
Any alternative intercooler thoughts? Water meth is a good solution but I don't particularly like the thought of having more fluid tanks to keep full. Water meth can also effect the engine tuning too. Has anyone tried air to air intercoolers on a boat before? What about a replacement intercooler from an aftermarket supplier like Frozen boost?
Give Dustin a call at www.whipplesuperchargers.com. All of their intercoolers are made of cupronickel and salt has little to no effect on them. They replace or sit under most manifolds.
| All times are GMT -5. The time now is 08:54 AM. |
