-   -   6.2 MPI problems (https://www.offshoreonly.com/forums/general-q/299571-6-2-mpi-problems.html)
jetskidrewski 07-10-2013 08:55 PM
6.2 MPI problems
2002 6.2 MPI - bought the boat about a month ago. ~90 hours on the original motor/drive
Short story:
- seems to have a hard time starting and seems slow to get on plane, like its starving for fuel
- brand new fuel filter and fuel/water separator
Full story:
- First couple times out seemed to run great no problems.
- about the fifth time out had a low battery and wouldn't start it turned over a couple times, backfired a couple times but wouldnt actually start
- replaced the battery that day then took the boat out.
- seemed to have a hard time starting, later that day went to get on plane and wouldn't go over about 2000 RPM
- next morning replaced the original fuel filter and fuel/water separator
- started the boat and realized the serpentine belt wasnt moving
- replaced the original 11 year old impeller
- started the boat, seemed like a bit of a hard start, but OK
- ran the boat again, semi-hard start at the dock and a couple times on the water, not like when I first got the boat
- also seems to plane quite a bit slower than when I first got it, feels like its starving for fuel.
Any thoguhts? Help would be much appreciated!
Expensive Date 07-10-2013 11:34 PM
What is your fuel pressure?
Did you change both filters if its the same as mine.
Tired, we will talk later.
Captain YARRR 07-11-2013 12:56 PM
I have been through this with both my engines and each time it was the cap and rotor. If you haven't had these done recently that's a great place to start including wires. It is amazing how crappy a boat will run and have trouble starting with corrosion on the cap.
jetskidrewski 07-11-2013 10:18 PM
Update: Pulled cap definitly has corossion. Will replace tomorrow and provide update.
Captain YARRR 07-12-2013 09:42 AM
Awesome, hopefully that does the trick for ya!
jetskidrewski 02-25-2016 09:37 AM
I should have updated this a long time ago, replaced rotor and cap, did the trick! Never would have expected that on a 2002 MPI engine...
BUP 02-25-2016 12:08 PM
very common problem the HVS caps do not vent at all. Even 2 year old caps are bad in humid weather.
Captain YARRR 02-25-2016 07:25 PM
Glad it did the trick!
