Re-power with triples? Stagger twins? OR Twins with a larger cockpit?? >
Old 07-15-2013, 10:31 PM
johnnyboatman's Avatar
I love it, leave it as is, but why three rh props
johnnyboatman is offline
Old 07-16-2013, 07:26 PM
cougarman's Avatar
Originally Posted by Pier45
Back in the boat owners club after a few year hiatus. Just took over ownership of a '95 43' Scarab a few weeks ago, and it needs help. Currently set-up with triple HP 500's with Bravo 1's. 1 engine is ok, the other 2 need help.... Do I yank them all and re-power with all 3, or do i consider a staggered set-up with 2 big boys. Considering this since i definitely have the hatch room. Or do i consider just putting in some high horsepower 2 rear engines?? I realize any option the includes eliminating 1 of the motors will more than likely require a drive upgrade, as it will take more hp from 2 engines, to run as effectively as it did with triples..... Any input on anything would be great
Well it comes down to what you want, it will cost you $$$ either way and you will NOT increase the resale.
I would leave it tripple before having a high HP Side by Side.
Cons to a tripple is:
1) Tripple everything, Oil, belts, etc
2) Harder to work on
3) Hard on the center Drive and Hard on the center Prop.
typically run a right hand drive and prop on the center
because they are easier to locate parts etc,
Center Drive works the hardest and is at risk the most due to it's depth.
Pros:
Looks and sounds cool as heck!
Side by Side:
Easiest conversion, but if you UP the power, probably should put on better drives.
Pro's:
1) Only patch center hole in the transome
2) One less engine and drive to maintain
3) Lots of front space in the engine bay.
Cons:
1) Big power in a side by side to equal a tripple
2) New drives
3) May not meet your expectations for speed
Staggered Twin:
Most work, but also the most benifits.
Work required, redo the transome, redo the stringers, redo your engine and drive rigging.
Pros:
1) Two engines and drives to maintain.
2) Room all the way around your engines to work on them
3) Lower center of gravity for better handling, ( Engines lower, boat is higher )
4) Only need 50 hp. more per engine to achieve the same as the original tripple set up.
( tripple 600's = Twin staggered 650's ) John Pompi master engine rigger shared this
with me years ago on a conversion he did.
5) Boat's most efficient and fastest set up.
Cons:
1) $$$$$ and time for your conversion, granted you can sell your third set of hardware
to help offset the cost.
2) New drives to do it right
3) Loss of cockpit space ( If it were a new boat )
Hope that helps
Jon
cougarman is offline
Old 07-16-2013, 08:56 PM
Registered User
bcfountain's Avatar
Interesting reading
bcfountain is offline
Old 07-16-2013, 09:42 PM
eddie's Avatar
I'm converting a triple 42 Fountain now to twin staggered, you can have Vincent do the stringers and transom. It's cheaper that one would think.
How did you guys end up with the boat after all?
eddie is offline
Old 07-16-2013, 09:47 PM
eddie whats the cost of just the glass work to convert from trips to staggerd
Old 07-16-2013, 09:50 PM
eddie's Avatar
My guy told me $3,500 - $5,000. He's done them before.
eddie is offline
Old 07-17-2013, 02:22 AM
Received 1,740 Likes on 860 Posts
Originally Posted by romie
Yes thats how i got it. Is there a better set up as opposed to 3 RH?
Yeah...one of the outside ones should be LH rotation. Which one depends on if you would like more bow lift.
I can't believe it does not pull to one side. It will ride better and dock much easier as well.
Griff is offline
Old 07-17-2013, 07:00 PM
romie's Avatar
Does not pull at all, docks easier then my 1 screw did. I thought 2 screws is were you would notice the most. I am curious to see the difference, just not curious enough to hang a LH on it.
romie is offline
