-   -   Gaffrig Gauge Questions?? (https://www.offshoreonly.com/forums/general-q/300028-gaffrig-gauge-questions.html)
TC G 07-19-2013 03:39 PM
I have 2 questions in regards to my Gaffrig gauges. My boat is a 97 27' Fountain Fever. I believe the gauges are original.
First Question: My fuel gauge is stuck on the full reading. Does this sound like a gauge issue or is there a sending unit that I can replace? (I had to do this once in my Mastercraft)
Second Question: My oil pressure gauge is always pegged and the red lite is always on. I dont get any alarms and my oil temp is ok so I just think the gauge has gone bad??
Any thoughts would be appreciated.
TC G
Griff 07-20-2013 12:18 AM
Is the fuel guage staying full or completely pegged??? If its pegged, then its probably a loose ground wire on the sender.
The tank sender is probably under an inspection cover under the back seat.It can also be adjusted with the tiny phillips head screws.
I had the same issue with one of my Gaffrig/Livorsi red line oil psi gauges. The gauge was bad..
Once in a while, used and NOS gauges pop up on ebay.
GAUGETHIS 07-21-2013 04:56 PM
Give us a call at 847-752-2424 Livorsi Marine
TC G 07-25-2013 07:54 AM
I think you're right about the ground wire. I replaced the gauge last night and it is still pegged. This weekend I will go looking for that ground wire. You think it is under the seat on a 27 Fountain? It would be awesome if it was.
TC G
BenPerfected 07-25-2013 08:54 AM
We have two sets of Gaffrig Red Light gauges in black we are not using.
Griff 07-25-2013 11:48 AM
TC G
More than likely there is an inspection plate under the back seat.
