-   -   apache scout motor height (https://www.offshoreonly.com/forums/general-q/300035-apache-scout-motor-height.html)
adrianvoje 07-19-2013 06:47 PM
just put 87 scout together with 2.5 merc it has set back bracket plus manual jack plate .dont know where to set prop shaft on boat any one have this set up and know the dos and donts thanks
turbo rr 07-19-2013 07:19 PM
Rule of thumb is run it as high as you can get good water pressure....You should post this over at screamandfly...you will get much more responses there.
J-Bonz 07-21-2013 10:13 PM
Good question. Luckily I have a hydraulic jack plate. To be honest, I am still trying to find the sweet spots. I agree with Turbo, ScreamandFly will be your best bet to get some good input.
Jr.
adrianvoje 07-22-2013 07:21 PM
is there anything you can tell me about set ups iveonly had a hydrostream vegas and this bot is so vwdifferent
J-Bonz 07-22-2013 09:52 PM
I would check out the Rigging a 21 superboat thread on S&F... I would think to get the most out of the boat I would go with a hydraulic plate...
Jr.
