| Steel Outlawed |
07-22-2013 07:57 AM |
Oil pressure sender 500 EFI
Will an Autometer 2242 100 psi oil pressure sender work on a 500 efi with Livorsi gauge. The specs for the sender say for short sweep gauge and I was not sure if it would work correctly or not. Any other recommendation would be appreciated. I need to get this by tomorrow and no one has the Mercrusier part (87-815425T) in stock. I'm prety sure that the Mercrusier part has the threaded pin for the sender wire and if you go to the auto parts store and try to get one for a Chevrolet 454 they all have a spade connector and I don't want to put a new connector on the wire.
