Different 502s
Whats the difference between a Mark 6 and Ram Jet 502's?
Thanks |
The Ram Jet 502 is a crate engine from GM Performance. Its basically a fuel injected ZZ-502.
There is no such thing as a Mark 6. What you are referring to is a Gen VI which is a roller cam block. Its the latest generation of big block from GM. It was available in a 454 or 502. GM dropped the Mark desigination in favor of the Gen designation ever since the Gen V came out. The first production 454 big block Chevys were called the Mark 4. The block remained esentially the same until the mid 90's when the Gen V was introduced. The Gen V had different oil passages and a one piece rear main seal. The Gen V was only out for a couple years until the Gen VI came out. Its basically the same as a Gen V but its made for a roller cam from the factory. Ron |
| All times are GMT -5. The time now is 06:59 PM. |
