-   -   Biggest cam in 502mpi with out reversion with stock manifolds? (https://www.offshoreonly.com/forums/general-q/300950-biggest-cam-502mpi-out-reversion-stock-manifolds.html)
tdpb2008 08-06-2013 08:19 AM
Just wondering what cam I could go with without changing my factory manifolds so i can keep quiet choice? And what kind of hp am I limited of making using my stock manifolds without supercharging
I'm planing on pulling my motor this winter and would like to make some more hp
bcfountain 08-06-2013 08:44 AM
I have a 502 non efi.i am running emi exhaust manafolds w/short risers by emi.i am running a comp 11-232-3 cam.this is a flat tapplet hyd cam.the specs are 505 lift on intake and 515 on exhaust 262/268 dur.110lobe centers.i have not had any problems with reversion.
liquidlounge 08-06-2013 09:22 AM
you are already at the max duration wise.(224/224 @.050 or somewhere there abouts) You could go higher on the lift and shorten the gross duration and it would run stronger and should still work decent with the stock intake.....no sense in going much bigger with that intake anyway.
tdpb2008 08-06-2013 10:50 AM
Next question is if the intake is a bottle neck should I keep the efi or go carb
I'd like to be around 600hp but also be reliable also
