Ecm recalibration ? Pcm0701
Have twin 2007 496 mag ho s could not get the iac valve to work finaly switched ecm (pcm0701) with other motor problem resolved in original motor and then moved to 2nd motor any one know if i can get my ecm reprogramed ? Thanks
Originally Posted by jps
(Post 3978012)
1) Dustin @ Whipple Industries supercharger, 2) Simon motorsports, http://www.simonmotorsports.com/ecu/optiecu.htm 3) Mercruiser factory by way of having a helpful Mercruiser dealer send it in for you as long as they trust your diagnostics without doing it themselves. Good luck.:) |
Pretty common. A faulty IAC damaged the PCM. Whipple can repair it.
Bob Lloyd Full Throttle Marine
(Post 3978012)
thanks that was the problem had something burnt out in ecm
| All times are GMT -5. The time now is 07:56 PM. |
