-   -   Can a dirty IAC muffler affect top speed in a 496 HO? (https://www.offshoreonly.com/forums/general-q/301908-can-dirty-iac-muffler-affect-top-speed-496-ho.html)
peaceman34 08-23-2013 03:23 PM
I've lost 7-10 MPH of my top end, can a dirty IAC muffler do this?
Flyin-Bryan 08-23-2013 03:31 PM
are You still making full rpm's?
peaceman34 08-23-2013 04:14 PM
No, I used to run at 4800 RPM and 67 MPH with a GPS. Now U I run about 4500 RPM and 58-60 MPH. I replaced the water /fuel separator but that didn't help. I just replaced the IAC muffler and it was black. I am getting ready to test it now.
JaayTeee 08-23-2013 05:14 PM
There's a fuel filter in the fuel pump assy, check that.
peaceman34 08-23-2013 10:11 PM
Well that did not do it. Do you mean the cool fuel filter? Is that hard to change? I have the older gen 2.
JaayTeee 08-24-2013 09:32 PM
Do you have this style pump ?
http://www.mercruiserparts.com/Show_...9+%26+Below%29
That has a filter in it
BUP 08-25-2013 01:46 PM
he has Gen II cool fuel system with the spin on fuel water separating filter. The diagram above is Gen III and number 23 is the most important filter in that set up that needs to be changed on top the filter # 28.
Anyways back to your gen II cool fuel system as it will have a tiny filter screen underneath the fuel pressure regulator that becomes very easily blocked. I would check that out. The first test to do is a key on fuel pressure test and then running fuel pressure tests to see what your specs are compared to your app..
Next I would have your motor scanned and drop test each cylinder to see the reduction numbers. You are looking for equal amounts across each cylinder performing that test. Also you are looking for when scanning the engine available power % plus any fault codes.
Also if a scan tool is not available for testing, you should perform a compression test and a leakdown test. 7 mph is a lot so maybe you have a motor problem and or prop problem especially with reduction of rpms so there is a lot more going on than a dirty IAC muffler.
peaceman34 09-19-2013 09:39 PM
I feel like I have very little response over half throttle, the first half is great. Is that screen hard to replace?
babalu 09-20-2013 09:37 AM
with diagnostic tool check for faults , for example , faulty IAC will turn on engine guardian that will reduce engine power
peaceman34 09-20-2013 09:39 AM
Shouldn't I hear beeps when it is in guardian mode?
jps 05-19-2014 05:21 PM
just a note be careful putting the iac muffler back in , mine got compressed to much and was throwing iac code and ruff idle drove me crazy trying to figure out also I've had bad iacs with full power 2 beeps every minute or two
jps 05-19-2014 05:29 PM
just a note be careful putting the iac muffler back in , mine got compressed to much and was throwing iac code and ruff idle drove me crazy trying to figure out ,I've had bad iacs with full power 2 beeps every minute or two also had a bad iac burn some thing up in computer whipple industries fixed computer
Keith Atlanta 05-19-2014 06:03 PM
Check your codes. Could go into "soft" and not sound an alarm and reduce engine performance to 70% (I think its 70 anyway)
For example, the temp sensors on the exhaust will hold back engine performance if its too high/low. I also think it will reduce it for knock sensor. I am going off memory and not the manual.... just things I have dealt with in the past.
Bottom line, dont guess! Scan it! Then get a buddy and scan it while running - then you will see all kinds of stuff.
