-   -   Help! Gasket material question (https://www.offshoreonly.com/forums/general-q/301970-help-gasket-material-question.html)
Aasved 08-25-2013 01:11 PM
I have a gasket leaking on my gas tank sender. After looking around at all the local performance stores I could not find any sheet material that would work in stock. I eventually Got some from CP Performance in a sheet material. Its a Cellulose/Nitrile gasket. Is there anyone with known knowledge of this material that knows if it is fuel resistant? I have not found a for sure answer on the net and Jim at CP was not totally sure but said it should work. Also I am having trouble finding fuel resistant gasket dressing like hylomar. I cant find the permatex anywhere in stock. I need some help! :D
mallatt442 08-26-2013 07:27 PM
I would use Mercury Perfect Seal for a gasket dressing....
FIXX 08-26-2013 11:04 PM
west marine use to sell just the gasket for the sending unit for a few bucks..should be made out of a cork looking material..here is another place..http://www.shock-price.com/result/s_...it-gasket.html
ezstriper 08-28-2013 10:29 AM
I used the thick rubber one...cheap
kvogt 08-28-2013 10:36 AM
EPDM would be my choice
