Gimbal bearing
Is there different gimbal bearings between the b1-x-XR drive?
Or are they all the same now? |
I believe the XR takes a different bearing due to the larger diameter shafts . My bud just made this change and it is simple .
If it has a red dot it will work for all
If you buy a new bearing, there is only one now that works for both. Non greasable.
if you get the gimbal bearing from sierra you can still grease it. I just put one in about 4 hours ago
I have the one with the white dot from merc is that the newest one it can not be greased
| All times are GMT -5. The time now is 06:17 PM. |
