-   -   Running out of gas (https://www.offshoreonly.com/forums/general-q/302384-running-out-gas.html)
sdrockslangers 09-02-2013 01:09 PM
Running out of gas
I have a 86 400 Scarab with twin gen 4 bbc .40 over 177 blowers stainless exhaust with 950 Holleys. 94 jets in front with 6.5 power valves , 98 in the rear no power valve. Holley 130 mechinacial fuel pumps and 3/8 fuel line, PSI set at 7
When I am cruising at 3000 boat will surge and sometimes pop. I back out of throttles motors will idle fine the a few seconds later when cruising again it will surge like it is running out of fuel. So back to the the dock I went. Any ideas
Thanks for the help
Steve
mike tkach 09-02-2013 02:56 PM
if you are not boost referenced the 6.5 power valve is your problem,or one of them.
jamontes 09-02-2013 05:56 PM
Mike - can you elaborate? I am chasing a low power problem on my 540/250 combo but only on one engine. I am a running Nickerson 1050's with 98's in the front and rear with a 6.5 PV. AFR's on all banks are in the 10.5 range (plenty rich) at 3Kish but the port doesn't want to rev any more... Sorry for the thread high jack.
sdrockslangers 09-02-2013 06:23 PM
Power valves
Do you think should go bigger or smaller. I had the 8.5 in before the 6.5 PV. Does the same thing with either ones. I
Thank you for your time,
Steve Vasquez
QUOTE=mike tkach;3987285]if you are not boost referenced the 6.5 power valve is your problem,or one of them.[/QUOTE]
mike tkach 09-02-2013 07:27 PM
most non referenced engines work best qith 10.5 or 9.5 pv,you may have other problems.
mike tkach 09-02-2013 07:30 PM
10.5 afr at part throttle is way to rich and robbing a lot of power,are you diluting the oil with fuel quickly?
nonstop 09-02-2013 08:43 PM
I have a almost the same set up. I have a 24 Scarab with a blown 489. Small 174 blower. Dean did my 850. Its now flowing about 920. I have 4.5 pv front and rear. My jetting is 90/91 front and 92 rear. I run 7psi fuel pressure and my plugs look great. .I'm a hair under 80mph. Check you air bleeds. Check to see if your anti siphon valve from you tank is good (if you have one). I had one go bad on our express cruiser.
