suggestions on heads, cam, intake swap..
I have a '94 Rinker 236 with a carb'd 330hp 454, bravo 1 with a labbed 23p mirage+ that will run 60mph gps at about 4400rpms. I'd like to turn it closer to 5000rpms. I was thinking about swapping heads, cam, intake and exhaust over the winter and Im looking for some suggestions. Id like to keep the silent choice also..
http://i163.photobucket.com/albums/t...psd8494bae.jpg |
what comp ratio is your eng now? and what cc are your heads, most perf cams want higher comp ratios to work well. you can get smaller chamber heads to bump it up using the oem pistons, run a roller cam, talk to a few of the engine builders that advertise on oso, have them spec you out parts that will work well together...rm
fixx
Originally Posted by downforce137
(Post 3993690)
http://i163.photobucket.com/albums/t...psd8494bae.jpg Edit but because of the cast internals your limited to around 400 hp with the pee pee 3/8 rods.. now if your willing to do some modes to the bottom end then i would suggest to go with a 496 stroker kit with a forged crank and a nice set of forged pistone and i beam rods..you can get away with a set of 088 cast heads for now and with the rite cam and intake and carb you could get over 500 hp easily.. |
the 330 hast cast internals. there are many threads on building that motor up but you cant go far before you start picking up pieces of crank and spare rods out of the bilge.
im surprised to hear the responses here. ive read many threads about 450-500hp 330hp 454's. the range on the sticker is 4600-4800rpms. i would think turning it 5500-6000rpms would blow it up, in no time, but thats not in my plan. I'd prefer not to go thru the bottom end at this time, as i only plan on keeping this boat for 2-3 more years before going to a 28ft.
Well if you plan on unloading it, keep it stock. If you start tweaking on a stock merc motor to increase performance you will decrease resale.
that hull was never meant to go fast, sell it buy a faster hull design.
Originally Posted by phragle
(Post 3994996)
Originally Posted by zeke
(Post 3995013)
Heads cam, intake, carb and exhaust will run you more than 5k. It is simply not worth spending 50% of boats value to go 5 mph faster. If you want more rpm, go to a 21" Mirage Plus or have BBlades lab the prop. |
well I sure wish someone would of told be to buy a faster hull then try make my Baja 272 go fast LOL
I'd like to see a true 500HP 454 CI that turns 4600-4800 RPM
I hate to say it, but the other guys are right. If you are only planning to keep the boat for a few years, leave it stock, enjoy it, and take great care of it. That is a real nice boat, but not the type of boat that people go shopping for if they want a go-fast type of boat. You will kill the resale on it if you hotrod it. If you just can't help yourself from tinkering with it, then buy another complete 454 (or 496 or 502) and build it up. Then when you get ready to sell it, you can swap the stock power back in and possibly sell you hotrod engine or drop it in the new hull that you buy.
I have been working on a pretty stout 496 for my old Baja - for going on two years now. Kind of wish I had just slipped a stock 454 back in it - I would have been running my boat on the water by now. |
I did a bunch of upgrades to a 454 that are in this forum from about 3-4 years back. You might want to look it up. I did 396 heads, cam, ignition, carb, intake, etc. .... Good info.
| All times are GMT -5. The time now is 07:22 AM. |
