496 H.O. two beeps when motor is not running
496 H.O. two warning beeps when motor is not running, Oil has just been changed and full 9 qts, Outdrive oil has just been changed and full to the reservoir, coolant tank is full, Reminder, motor is not running, I am thinking a loose connection somewhere?
It could be one of 10 different things. No way to know without scanning.
496HOs only take 8 quarts of oil. |
9 with filter and lines, I change it every 15 hrs.
Is it only when you first turn the key ?
Yes
If you turn the key one click the alarm will sound to let people know behind the boat it's about to be started!
Yes, I get the initial safety single long beep as you turn the key, that stops then I get a double beep and it stops.
I have a 7.4 MPI Bravo 3 and I get two beeps when I turn the key on - agree to warn people that the engine is starting. Then when I shut the engine off I get two beeps - or more like two cherps.
3pointstar |
Gotcha, I would have it scanned to be safe! If no warning when running it could be sending you a low oil pressure warning till you start it and the oil pressure builds ! Just my 02
Will an OBD2 scanner work on these motors or do you need a Mercruiser scanner?
| All times are GMT -5. The time now is 10:25 AM. |
