Carter mech. fuel pump #0-2208 help...
Is there a replacement at an automotive store? If so
What's the part #. Or is there any where else that sells It other than Mercruiser? It came out of a Mercruiser 502 EFI around a '94 model and it's the pump that mounts on top of the sea pump. Thanks |
The replacement pump I'm using on a '96 502mag is Airtex #60932, $55 on Amazon.
Drops right in, be sure to save the 1/4"NPT tube fittings from your other pump. |
| All times are GMT -5. The time now is 09:18 PM. |
