-   -   Need a intake for 500 HP which one? (https://www.offshoreonly.com/forums/general-q/304231-need-intake-500-hp-one.html)
racer-x6 10-15-2013 01:08 PM
Who makes a replacement intake for a stock 500 HP?
Dart single plane rectangle port 4150 9.8 deck??
guess I will have to drill the PCV hole?
mike tkach 10-15-2013 06:44 PM
dart makes the manifold for merc,fixx knows the part number,im sure he will chime in sooner or later.
FIXX 10-15-2013 07:36 PM
unless you can find a clean oe one then tes you will have to buy a dart one and you will have to drill and tap the pcv hole and drill the intake for the pcv ...you can ask dart to do it for you for a fee..your intake is a dart with the dart ground off the intake,if you look close you can see where they ground it.#41114000GM is the replacement..make sure its not a bull dog engine,that one is a diff manifold
