-   -   1995 525sc plugs (https://www.offshoreonly.com/forums/general-q/304246-1995-525sc-plugs.html)
gerg g. 10-15-2013 07:54 PM
1995 525sc plugs
putting boat away for winter and want to change plugs. has ngk v power -7 in it crossed over to autolite ar 135's but both ngk's and ar135's seem to be hotter than the mr41t's that are called for. want to use some plugs i can get easily. just looking to see what others are using. thanks.
romie 10-15-2013 08:02 PM
Ac 41t
gerg g. 10-15-2013 08:12 PM
can't seem to to find 41t's locially that eas my first thought
mike tkach 10-15-2013 08:13 PM
ngk-8
MILD THUNDER 10-15-2013 08:18 PM
5673-8 for the NGK's. Parts stores stock them under part #3249. Those are the plugs I run and like in my blower engines.
Another good plug is the AR134 Autolite racings. Those would be the stock heat range from mercury for your 525SC.
Rookie 10-15-2013 09:06 PM
How long have the -7 V Powers been in there and have they been working? That's a good plug why change?
I use them in my NA application and was just going to leave them in there if and when I bolt on my blowers.
gerg g. 10-16-2013 08:02 PM
v powers have about 21/2 yrs on them no problems just thought now is a god time for a fresh set. back seat assembley is out for winterization. and v powers are harder to get. autolite ar's are redialy available. ar 135's cross from the ngk-7 but both are a heat range hotter.
