Thinking of running a crossover
I also have some questions about the pros / cons of the circulating pump, i have a dart 598 cui. 770hp@5500rpm
Currently i have no thermostat for water, and my oiltermostat doesnt do the job good enough..
My engine runs too cold and i have a big condensation issue..
I have a solution for the oil, but not for the water..
thinking about running thermostat but not an circulating pump..
Is there any risk of the back of the engine running hot?
Im going to use a bypass.
I run in cold water, about 64 farnheit
Sorry, didnt find any better pictures:
I'm running 700hp with a crossover with a Stewart thermostat and bypass and no oil thermostat and I run in water as cold as 34 degrees and as warm as upper 70's. It works great engine warms up quickly, zero condensation problems. The only time it gets a little out of spec is when I've been running hard and drop to an idle, my oil temp will climb to 270 and then drop to 190.
