Most inches I have ever actually saw in a Std. deck GM 454 block is 526. That was 4.375 bore and 4.375 stroke. It was for a sled pulling truck that the rules limited you to a factory Std. deck block.
Originally Posted by dandercam1
(Post 4020634)
Running a internally balanced 4.25 crank requires going to 6.385 or longer rods to clear the counterweights which helps rod/stroke ratio and piston side load issues. Going to the 6.535 rod with the 4.25 stroke results in a better rod/stroke ratio than a stock 454 or 502 but works best in a tall deck block. Scat did make a cast externally balanced 4.25 crank that worked with 6.135 rods but I don't know of anyone actually running one.
There are tons of GM blocked 540's out there but that's not to say that a Dart block isn't the way to go if you are starting from scratch. I think it is safe to say that not one of those 540's started with a 454 block. I did however know of a 565 that started out as a GM 427 tall deck truck block. |
Yup ....you cant bore it that much. You can still make nice power out of your 454 if you have top shelf parts and the right components turning 6000rpms. My 454 was bored .30 over and makes 603hp/590 tq at 6000rpms.
Originally Posted by Checkmate283
(Post 4020682)
Also can you tell us what fuel set up you are running along with is this EFI or carb motor. Also is this a NA engine only.
Originally Posted by mike tkach
(Post 4020669)
what was the bore&stroke of this 565 gm talldeck truck block?
(Post 4020669)
Originally Posted by danny4pr44
(Post 4020460)
If some one can help to make my 454 mpi to 540 or tell me the parts that I need?
Originally Posted by GPM
(Post 4020875)
Put this on and it will run like a 540. http://www.offshoreonly.com/forums/s...ml#post4020863
Common Danny4pair-underwear, don`t let these guys push you around! They can`t agree on anything! You know you can do it so stop asking on the internets machine and get to work! I bet it`ll be an awesome build! Maybe you and Borgy can collaborate.... throw some peanut ports on that bi #@tch and make it scream! Go FOR IT!!
| All times are GMT -5. The time now is 06:34 PM. |
