How much total timing for Aluminum head 509??
5 Attachment(s)
I am getting ready to fire my engine by the end of the week and was wondering how much total timing to use? I am thinking about 34 degrees and was looking to see what other similar combos have used? Here are my engine details:
.030 over 502 forged GM 4" crank scat h-beams with probe mid-dome forged pistons. Pro-Comp aluminum heads with good valve job, chamber work, and rocker geometry issues corrected. Extensive deep port matching to FP 1275 gasket so 320CC intake volume was increased. 496 exhaust Aluminum and ceramic coated. turbulators removed as well as all baffles/mufflers. Corsa Captain Call with new diverters and flappers on the back. RPM Air Gap intake also deeply port matched to FP 1275 gasket with Mighty Demon 850 with 1" open spacer. Cam is .611int/.595ex 228/[email protected] 114LSA 18726543 LS style firing order. Comp SS 1.7 rockers Thunderbolt IV Ignition with 22* module if I can find a pigtail to plug it in? Fuel will be 93 from the gas station as I am looking at 10-1 CR .......................... Donzi 26ZX with Bravo 1 26P prop looking for 52-5400RPM max. 90% of the time cruising at 37-3800rpm So there is my question, how much timing with aluminum heads running 93 octane? There will be times I will have to put some 89 octane in on the water but if that happens, I will be proactive and leave at least a 50/50 mix hopefully! I will be running closed cooling as well with cool engine temps but it gets hot here in Tampa. So, is 34 a pretty safe number? I figure initial will be around 12* with the 22* advance module....... I dont want to get into any detonation as I dont think these procomp heads will take much abuse......TIA TBF [ATTACH=CONFIG]512218[/ATTACH][ATTACH=CONFIG]512219[/ATTACH][ATTACH=CONFIG]512220[/ATTACH] |
34 is safe. it may like 36
Are you running it on a dyno first where you can see what it does ?
If not I would also stick with 34 |
OK thanks... this is my first dunk into the go-fast pool and I don't want to eff this up for being stupid! I am not out for every last possible bit of power but if I can get this thing to go 70MPH reliably than I am happy. I do have a wide band exhaust plate on the top of each manifold for a data logging LM-1 and I am installing a wide band gauge as well so I can tune this properly from actual conditions on the water...........
10:1 CR. running 36 degrees on 89 octane, I would have some concerns with that.
I would recommend spending the money on the dyno. Looks like you have spent some money and time. Without dyno testing you maybe leaving power on the table, let alone break-in under a controlled test. You will have unknown A/F #s and stepping your timing not exactly knowing, what the engine wants. If you had a stock engine rebuild, might be a different story. |
Sounds like a great project I have a similar 509 in our Pachanga (SeaRay) take a look under the SeaRay area on this site, it's running on the dyno....34 is safe but leaves alot on the table 36 made 40 more HP.
Man I did not want to hear that! 40 HP is significant...... 10HP or so is not such a big deal. I did have the engine in line for dyno testing but I could not wait any longer..... My engine guy has a lot of real exotic stuff going right now so I understand how that goes........ As far as fuel, 93 pretty much all the time but I am sure I will have to buy on the water on occasion, if so I would maintain a minimum 50/50 mix between 93 and 89 so 91 would be more likely the min....... with the data logging LM-1 and wide band gauge as well I can keep a pretty close grip on AF ratios. I built this motor at 10-1 knowing this was about the most you can use running aluminum heads......
What kind of cranking psi are you getting on a compression gauge?
with out any knock control 32-34 max,i usually build my motors 9.2 -9.4 with aluminum heads 34 total timing
Originally Posted by MDGperformance
(Post 4026022)
I'd be conservative on timing in hot humid florida sea level air with 10:1 and a relativly mild low rpm camshaft. |
| All times are GMT -5. The time now is 02:24 PM. |
