which 502 do I have? it sure would be easy if a parts vendor added a search engine!
serial tag is D845014 block casting looks is 14096859
trying to determine year generation etc thanks in advance |
block is 502 ho gen5 thats all i can come up with.
You don't need a serial number for that info.
If it has a fuel pump mount on the engine block, its a Mark IV If it has no fuel pump provision and a stamped steel timing chain cover, its a Gen V. If it has no fuel pump provision and a cast timing chain cover, its a Gen VI |
Originally Posted by Griff
(Post 4036886)
Marineengine.com
Chose search by serial range. Simple to use. |
| All times are GMT -5. The time now is 07:09 PM. |
