Ditching the power steering cooler
Cleans things up, eliminates a few lines. Anyone ever do this? How hot can the power steering fluid really get?
im certianly no engineer but keep this in mind,every boat with power steering assist that mercury produces has a cooler.if it was not needed merc would not put it on,id keep the cooler.
Originally Posted by mike tkach
(Post 4043114)
Drove a Donzi that had a very small cooler and no external reservoir, after a hard run the fluid aerated and steering sucked around the docks.
ICDEDPPL - Great minds think alike...
Did it. Got the t-shirt. 2 years ago. Bought a heavy duty off road trans cooler either 9 or 12 inch, cant remember, with AN fittings and a backup fan. Mounted it up in under the gunnell. Wired a switch to the dash. In ordinary lake/ICWW running it doesnt even get warm. Offshore hard running maybe a little and if you even question the temp, I turn the fan on. Had it like this 2 years+ Wanted to do an electric power steering pump too. Bought all kinds of electric motors and electric power steering pumps.... Failed miserably! Automotive is high pressure low volume. Marine is semi high pressure high volume. Latham has one for like $4000 and I wanted to do an eBay special - Couldnt even get it to move with offroad electric systems. So now its stock with the trans cooler. Let me know if you want pics. I will be out on it this weekend and will take a couple. |
I ran most of the summer without one, because it took a crap, and replacing it meant I would have to have pulled the engine. I didn't have any ill effects, but while the engines are out, I plan to install a new cooler. I actually want to mount it after my sea pump, so if I smoke an impeller, the steering cooler will catch the big chunks, rather than send it all into my bellhousing style coolers, which would suck to clean out.
Originally Posted by MILD THUNDER
(Post 4043171)
I don't have a PS cooler and never had problem.
(Post 4043114)
(Post 4043171)
Keith Atlanta ICDEDPPL - Great minds think alike...
Originally Posted by Griff
(Post 4043237)
You could install another cooler on the other engine and use them as fuel coolers. Cool that 95 degree fuel down to 65 degrees or so :)
I find that synthetic power steering fluid helps a lot, specially if you choose not to run a cooler
Latham says they are required. Coolers that is. 2x9 or 3x6 bundle length.
http://www.lathammarine.com/power-st...-coolers.htm#1 |
(Post 4043345)
Originally Posted by pqjack
(Post 4043353)
Actually, I run that in my power steering and trim and tabs.... cant say enough good stuff about it. I run a trans cooler on the steering but maybe thats why its never even warm. |
(Post 4043356)
http://www.lathammarine.com/power-st...-coolers.htm#1 Of course they do, if I was selling PS coolers I`d tell you you need one asap too .:) I`m going to ditch it cause thats the kind of rebel I am lol My BIG A$$ over flow holds some fluid I say good enough. http://33outlaw.zenfolio.com/img/s11...75909298-3.jpg |
I like turtles.
I would leave it....gets pretty hot in florida ...you will need it..lol
^^^^ oh snap lmao!!
I've always used a cooler and have in the past seen a steering pump overflow because of lack of the same .Seems like cheap insurance and ez to hide under motor
We talked with Tom Lee of Lee Manufacturing who builds racing power steering boxes, and pumps and he prefers the fluid temperature at 180 degrees F, but he also says anything below 250 degrees F is acceptable. What will kill pumps is temperatures exceeding 300 degrees F. |
Originally Posted by ICDEDPPL
(Post 4043690)
I bet with it never reaches 180* with constant cool water running across the cooler as opposed to an automotive application.
(Post 4043532)
I like turtles.
http://youtu.be/vZV07MOpMXo |
(Post 4043695)
Only one way to find out. Add a power steering fluid temp gauge!
(Post 4043816)
or run it without the cooler and burn up the pump!
(Post 4043823)
I'm thinking of eliminating my trans coolers
I`m just not feeling the love anymore :kiss:
Haven't run the PS cooler in four years, pump is still fine. Has anyone actually lost a PS pump because of overheating?
(Post 4043826)
may as well really clean it up,who really neads an oil cooler ,chitcan all the coolers, they only put them on to make money.:confused:
If you want to really clean it up, keep the P/S cooler and get rid of the chrome rocket launcher on the front of the engine :):evilb:
Originally Posted by Young Performance
(Post 4044121)
Originally Posted by thirdchildhood
(Post 4043767)
OMG lol This summer: Mike you wanna go for a ride .. hold on while I put on some music :lolhit: |
(Post 4044110)
Mike, have you considered removing your engines all together? It will really clean up the bilge and make working on them much easier.
| All times are GMT -5. The time now is 11:15 AM. |
