-   -   Looking for infos to convert an 8.2 MAG to HO Version!! (https://www.offshoreonly.com/forums/general-q/306713-looking-infos-convert-8-2-mag-ho-version.html)
Brembofreak 12-24-2013 04:28 PM
Hello from germany and merry christmas
i look for the right infos to convert the new 8.2 Mag to and HO version!
I get new engine for christmas and if i can do,i like to convert to HO version.
I ahve an non DTS engine!
So what is to do? The infos i have is that only the ECU has diffrent software and all engine parts are same.
Maybe someone here knows more??
also the ECU from HO version are only available with DTS. Can i use this ECU from an HO on my engine with no DTS??
Thanks for help and please ignore my writing mistakes!
! Michael
mike tkach 12-25-2013 03:51 AM
it is my understanding that the only difference is a cam change and a ecm reflash.
Brembofreak 12-25-2013 04:06 AM
Thanks!
This is what and 496 mag need to become an HO!
But they all say the new 8.2 Mag did not need any hardware. but i am not 100% shure and look for real infos!
I have checked partsnummbers by Mercruiser and 8.2 MAG and 8.2 MAG HO have exact same camshaft( Nr 8M0046343) in them! So this part must not be changed!
No problem to change an ecu,but HO from this model have an ecu for DTS only! So i look for infos if i can use the HO DTS ecu on my non DTS engine!
Michael
onesickpantera 01-03-2014 04:50 PM
Mag and HO cams have different part numbers, 431-881627 and 431-881628.
Brembofreak 01-03-2014 05:01 PM
Sorry,but you made a mistake!
this nummbers are from the old 496 engines with 8,1 l! they have nothing to do with newer 8.2 engines!
there is only one camshaft for all 8.2 engines that are from 2010 or newer!
we talk about the older 496 engine!!
michael
Baja226sport 01-04-2014 06:27 PM
The new 8.2 and 8.2 H.O. have the same exact part # listed for camshaft.
Brembofreak 01-05-2014 03:22 AM
That what i say! Only the intake adapter that take the flame arrestor are diffrent at HO.And this only at modells with mechanical shifting!
Michael
Pismo10 01-05-2014 01:51 PM
Sounds like you figured it out.
Brembofreak 01-05-2014 03:52 PM
:evilb:
Yes,looks that 2014 was an fast year for my Baja!!!
Theres an option for 430 Hp Ho Power or 475 Hp with 91 octane gas!
needs an softwareupdate an new intake adapter at this engine!
Real hot to know what this new 8.2 mercruiser can do on the water!
Michael
509 SC 01-05-2014 07:46 PM
Originally Posted by Brembofreak (Post 4052562)
:evilb:
Michael
This may be what you're referring to, but Whipple is offering an upgrade for your motor. There are a couple of mod levels to choose from
Brembofreak 01-06-2014 03:11 AM
Thanks. But a little to late this tipp!
I am some days in contact with dustin from Whipple Charged!
They have all i need.
Michael
mike tkach 01-07-2014 09:19 AM
oops,my mistake,wrong engine.
