Sheet Metal intake?
Just wondering if anyone has played around with these on a boat motor? I know it will make more power if done properly but I'm just wondering what the longevity is. Can they stand up to the constant bouncing around and not crack?
I ran one for many years, only put a little over 300 hrs on it. It was built by Hogan and it is built like a tank. A real work of art! Had it setup for two 1000cfm throttle bodies and EFI. Expensive but it did look cool!
Dick |
hogan builds some badass intakes.
most sheet metal intakes designed for drag race applications and move the better H/P higher up RPM wise than most of us use in boats...
When you build a sheet metal intake you are starting with a blank sheet of paper, so you can design them to preform where ever you want. Pleum size runner length and shape can be made to help work with your heads and cam. I just had Hogan build me 2 they are amazing
2 Attachment(s)
[ATTACH=CONFIG]515292[/ATTACH][ATTACH=CONFIG]515293[/ATTACH]
Billet runners, then we had them anodized. |
They seem to do fine in NA applications, as long as it's a quality built intake. The problems come in when guys try to use them with a SC on top. All the weight up top being bounced around is asking for trouble. I know a few guys that have tried and they all cracked constantly.
Eddie |
Originally Posted by KWright
(Post 4048306)
| All times are GMT -5. The time now is 09:45 AM. |
