Pink Mold
Old 01-05-2014 | 03:27 PM
Default Pink Mold
Any success stories on how to deal with pink mold on upholstery?
ciaoderhead is offline
Old 01-05-2014 | 07:59 PM
Leave it in the sun for a couple of days and it will go away.
Patience...myass is offline
Old 01-05-2014 | 08:31 PM
Clorox
Keith Atlanta is offline
Old 01-10-2014 | 04:58 PM
Ttt
Old 01-10-2014 | 06:11 PM
Have HER change her panties more often
mosi is offline
Old 01-10-2014 | 08:08 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Lin,
I had an issue with it mold cropping up on (only one) of my cars in my toy box some time back.
I found (at WalMart I think, in the camper section maybe?) and used this to clean it and deter it from coming back. It worked pretty well for me. It was not a pink mold, but it was light greyish-green.
That's all I got...
[ATTACH=CONFIG]516115[/ATTACH]
Sydwayz is offline
Old 01-11-2014 | 07:45 PM
Quite possible that it is the result of suntan oil, instead of lotion.
commandersander is offline
Old 01-11-2014 | 07:49 PM
How To Cleanup Pink Mold
The cleanup process is similar to the cleanup process for other types of mold. Start out by protecting yourself with the proper equipment, including goggles, gloves, and a mask approved for mold use. Be careful to not let the mold directly touch your skin. The affected area needs to be scrubbed down, and then thoroughly sanitized with a quality biocide to be sure that the organism is killed completely.
If any traces of pink mold are left, the problem will remain because the spores will likely continue to grow in the affected area. You can prevent the growth by sanitizing the area, and also preventing the buildup of moisture. Use a fan, and wipe down wet surfaces to prevent the water from sitting after you are done boating.
Also, this mold growth can be prevented by avoiding soap buildup on the surfaces affected. It is suspected that pink mold actually feeds on soap residue, so allowing the residue to sit may promote additional growth.
Old 01-12-2014 | 12:34 PM
http://www.pinkmold.org/pink-mold/pink-mold-dangers/
http://www.chemicalfabricsandfilm.co...moldmarine.pdf
Pliant is offline
Old 01-13-2014 | 07:12 AM
scarabman's Avatar
Yep. I have some slight discoloring in my upholstery, only in contact areas, and I am pretty darn sure it is/was caused by the spray on sun protectants. Never had an issue until my wife started using it on the kids. Stains will NOT BUDGE either.
scarabman is offline
