Need help with choosing cam
Here's what I got.
540 8.5 to 1 8-71 littlefield blower Heads are gmpp ported. They flow 321 at 6 and 335 at 7 I just had them done 2.30/1.88 inconel valves 170closed 460 open installed 1.95 new springs for hyd roller but I can change if need be Je pistons Oliver rods and dragonslayer crank 2 900 prosystem carbs that aren't built yet till we decide everything else Superchiller 3500 pound boat 26 eliminator Daytona 2001. Bmax new style 1.30 Btm msd ignition Cmi big tube wet headers Boost will be 5 to 9 pounds just don't know what to do yet. But would like to keep it at 1/1 or under driven I'm having a hard time finding a cam. So please chime in with any suggestions. It's difficult to choose from. Also would like to know the best lifters to run with cam if hydraulic is the way |
you would be very happy with a crane hyd roller,off the shelf cam 139651.i used this cam in a pair of blown 540s with chillers under 8.71 blowers with dart 320 heads.950 hp at 6500 rpm.this was with 9.5 lbs of boost on 92 oct pump gas.
also i would like to say a pair of quickfuel 850 blower carbs is my recomendation,i am not bashing patrick,s carbs but imo,you can,t beat the quickfuel deals.
If you do some searching you will see everyone mention bob Madera. All good. No bad. When I build motors for something he will be my first call.
Rmbuilder is his name on here. Marine kinetics is the company. |
Originally Posted by I.C.U.Lookin
(Post 4055620)
Thanks mike I will look into both of your suggestions. And the other so far I have heard of him on here from reading and will do the same. So far mike tkach ^^^ has been a big help too from the time of buying this boat so he deserves a lot of credit on this forum also. Someone on this forum under camshafts said to call Chris straub too I'm just trying to do it once and be happy with the boat. Since I've gotten it I've only got to use it for a total of 1 hr but been out 10 times so that should explain all the new parts too! I'm excited as heck to see what this motor will do vs the old badly built motor, but glad I could save a good few parts that came with it. And mike one of the reasons I do use Patrick is he built all of our drag stuff for years but this whole marine thing is completely different animal! But I will look at those like I said. Right now I will look at the cam then off to bed. Thx guys so far.:ernaehrung004::ernaehrung004:coolcowboy:
(Post 4055620)
Originally Posted by Wobble
(Post 4055622)
I agree, crane cams are a mixed bag. Definetly give Bob a call
Mike, I wasn't doubting ya bud. You are very knowledgable. Just throwing out ideas.
Originally Posted by mike tkach
(Post 4055659)
what is the mixed bag about crane cams,i have used a lot of them through the years with great results,have things changed with the new crane cams?
