-   -   Hot Oil temps---why???? (https://www.offshoreonly.com/forums/general-q/30739-hot-oil-temps-why.html)
Sean 08-13-2002 12:39 PM
Kool...now I don't feel so bad.
Thanks for the info...BTW, who is Dennis Moore?
Biggus 08-13-2002 12:48 PM
Dennis is the author of Big Block Marine Performance.
It is the best book out there as far as building a BBC boat engine.
He also wrote the bible on small block power.
Kurt.
Allan4 08-13-2002 05:57 PM
No one has mentioned low water pressure. The two of these combined (high oil temp and low water pressure) would mean either an impellar going bad or a clogged water line somewhere (probably from the impellar going bad as well). I'd look there if you are still having issues.
Allan4 08-13-2002 05:59 PM
Oh, by the way, 210* is probably hot enough to boil off condensation.......270* seems pretty damn hot, but D. Moore knows more than I do.......:D
blue thunder 08-13-2002 07:11 PM
That must be "new math" Allan4.... I always thought the boiling point of water was 212. :D .... I agree tho... the oil temp is probably above 212 up stream of the sender when the guage reads 210... meaning of course, allan4 is correct in reality.
BT :cool:
Waterfoul 08-13-2002 08:17 PM
I would agree with Allan4 (did I just say that??) about the water pressure. If the sender swap doesn't shed any light, start looking at the water system. And I also agree that 200 is too cool. Mine runs at 215-220 at 3500 rpm cruise, 230-235 at WOT blasts. Never goes above 240, even after several minutes of WOT running.....like chasing Rambunctious last Wed. on our JCI Poker Run. What a blast. Then again, the water was only 55 degrees that day. Brrrrrrr!!!!!!!!
Sean 08-13-2002 08:55 PM
Ohhh...that Dennis Moore...I thought you were talking about the other Dennis Moore:D :D :D
I just replaced both pumps, so I don't think that is the problem, so I'll look into swapping the senders.
Where do you guys have the sender located?
Thanks again guys!
Biggus 08-13-2002 09:13 PM
My senders are mounted in the remote filter housing. After a really hard run I`ll see 260* before the oil goes through the cooler.
Sean 08-13-2002 09:21 PM
Biggus...I never really realized that the temp was taken before the cooler, so that is another plus...
How about the oil pressure after the hard runs?
The reason I am asking so many questions is because this 540 had bearing failure and I thought is was due to the hot oil and low pressure...you see after a 230-250* romp, the oil pressure would go to about 5-10lbs when I dropped it to an idle...it got progressively worse until 2 bearings failed.
Now it seems that it will still get just as hot, but I haven't run it hard enough or long enough to see where the pressure is going to go...the goos news so far is that th minute I drop it down to idle speeds, the oil temp immediately drops...before, it kinda hung out up in the 240 range for a while...
I really don't want to be replacing another motor anytime soon.:mad:
Biggus 08-13-2002 09:45 PM
I`m not running any thermostats, oil or water. When cold, I`ll have almost 80 lbs and I do not rev it past 3500-3800 until the oil temp gets to 200* after the oil is up to temp the pressures will be around 40* at idle and 60* wot.
Good luck,
Kurt.
