Max power to TRS drives >
Old 01-18-2014, 01:25 PM
Default Max power to TRS drives
Whats the max power you can run with TRS drives? Im pushing 600HP and 610 ft lbs of torque and just wondering if I could do more?
Ct.Rice357 is offline
Old 01-18-2014, 04:38 PM
ROB FREEMAN's Avatar
youre pushing it . some say stronger than bravos .
ROB FREEMAN is offline
Old 01-18-2014, 05:14 PM
Def stronger than bravos, and I agree you're at the most I'd consider reliable
Unlimited jd is offline
Old 01-19-2014, 08:46 AM
the trans will usually fail first...
ezstriper is offline
Old 01-19-2014, 08:54 AM
I had a 402 Formula SR1 with 600hp and the trs didn't last long . A spare set of drives is a good thing. The BW 72c is a good trans. If beefed up they can take a ton of power.
MILD THUNDER is offline
