-   -   alterator on 454 mag help (https://www.offshoreonly.com/forums/general-q/308039-alterator-454-mag-help.html)
osure 01-30-2014 04:34 PM
Trying to get some ideas the alternator keeps not charging replaced 2 alt works great for 5min to 5 hrs with do issue then it stops charging. last fall it stopped working then 2 min before I was putting it on the trailer it started charging again. I have look at the wires nothing looks bad only thing I can think of is a connector. Any other thoughts?
MILD THUNDER 01-30-2014 09:25 PM
Check the exciter wires. You need 12v at the purple wire for the alternator to charge. Could be corrosion in those bullet connectors
osure 01-31-2014 01:01 PM
will do
crisistc 04-14-2014 05:39 PM
Any updates? I am also having issues with charging on my 1994 Baja 260. I just bought 3 Deka Group 31 AGM cells this season and took the boat out yesterday and at low idle it wanted to die all of a sudden and then could barely turn over. I switched the perko over to share the battery input to be able to start again. I have a feeling something is wrong with the alternator. I have thoughts on buying a MeanGreen high output what are your thoughts?
mike tkach 04-14-2014 05:54 PM
check your battery cabels for corrosian where the terminals hook to the wire,i have seen that cause problems.
crisistc 04-17-2014 10:36 PM
Battery cables are new. Seems to me the alternator has failed after 20 years in the boat. I have ordered a WEI 120 Amp alternator to replace it.
