Power valve in holley.
I am wandering if anybody runs power valves in there carbs? I have never ran one in my racecars but I do have one on my 355 sbc. It runs just fine I'm just curious if anybody uses them!!
I used pvs in both primary and secondary in my dominator, and made it run perfect throughout the power range. without them the carb is way to rich everywhere but WOT. I only used one on my Demon blow through. every carb is different and takes alot of messing around to get them right. But I recommend using a pv unless it only idle or wide open aka race car.
I'm running both in my Pro-Systems 950. It helps fuel economy when your not on it big time. My cruise speed is 55 - 60 and I get almost 3mpg with a 90+ top end. Once I get the prop sorted out I may break 3mpg. Not bad for a Velocity 280.
