-   -   Pro charger and carb Info (https://www.offshoreonly.com/forums/general-q/309114-pro-charger-carb-info.html)
MILD THUNDER 03-02-2014 08:48 AM
Originally Posted by ezstriper (Post 4083083)
I run a M3 only 5-6psi as of now, I talked to Patrick @ Prosystems, he did not want me to run without a box, as he felt there was not way to keep from blowing a small amount to fumes out thru the throttle shafts and in a enclosed engine compartment...not good...
Weird. My buddy had prosystems blow thru's, with the throttle shafts pressurized via fittings for that purpose.
motor 03-02-2014 08:53 AM
Do you have any pics of pressurized throttle shafts .I'm just trying to picture in my little brain,what you are describing
MILD THUNDER 03-02-2014 09:03 AM
Let me see if I can find one
green lightning 03-02-2014 12:34 PM
I was told by both manufactures that the only coast guard approved method of a blow-through carb application was with a box and if you had a fire your insurance co would not cover .
FIXX 03-02-2014 12:40 PM
Originally Posted by Fenderjack (Post 4083113)
ezstriper! So what configuration carb are you running.Is it set up for a box a blow thru or a stock type. JOHN SR
john, just remember you dont need alot of carb or cfm for a blow-through set up..all you may need is a 650 cfm carb..the air is forcing the fuel out of the carb..to be honest call c&s and have them build you a arosol carb with progressive linkage..i always use a carb that all four barrels open at once so your getting a equal fuel charge through the transition..their is a few tricks that need to be done to the carb in a blow through system..just changing jets dont cut it..you also have to open op the passeges to tje power valves to feed the bigger jets..just have c7s build a carb..http://www.candsspecialties.com/abcmods.html
ezstriper 03-03-2014 08:32 AM
I now am running our own EFI with a hat, using megasquirt, our own harness and tune...
ezstriper 03-03-2014 08:35 AM
He said even with "sealed" throttle shafts they do blow out a small amount of fuel under boost...said they noticed it on the dyno...
ezstriper 03-03-2014 08:38 AM
with carb...
http://i227.photobucket.com/albums/d...r/100_1741.jpg
ezstriper 03-03-2014 08:40 AM
with EFI
http://i227.photobucket.com/albums/d...pse6b4071c.jpg
mike tkach 03-03-2014 09:14 AM
does your megasquirt throttle body have a shaft for the throttle blade or blades because if so you still may have some fuel leakage under boost.the deal patric from pro systems sells for carb apps with a hat consists if modifying the carb and a plate under the carb.it is a really neat deal.
