educate me on Sea Strainers
Hello all,
I have been looking at sea strainers for my Formula 252 with 454. Some of the strainers I have been looking at the Groco ARG Series, Sherwood (plastic not sure about this), then it seems it just to the higher end units Gil, and Teague 5 inch unit. I am limited with space so of coarse the higher end units are smaller and seem to be a better choice. However, I have been seeing talk regarding pressure valves. Should I be concerned about this? My motor is stock so, I would guess my sea pump is not modified, but not sure if I should be concerned about a pressure switch. Additionally, on a stock setup are the Sherwood and Groco units any good? I really dont want to break the bank on a sea strainer. Any advice welcomed. Thanks |
I would stay away from anything plastic that's below the waterline. Of the units you mentioned, I would go with the Teague. You don't need a pressure valve.
Do you have freshwater flush on your boat? If not and you're installing a strainer, you should get one that has a flush inlet port. If you don't want to add the flush now, having the port will allow you to do it later and you can just install a plug in that port now. |
Yes I have a closed system with fresh water cooling.
any particular model?
Originally Posted by Priobe
(Post 4087224)
In either case, if you add the strainer, you will also need to add a ball valve in-line between the strainer and the intake hose coming from your drive and you said space was tight, so keep that in mind too. |
Oh yes, I have a flush its a Perko in line flush system, ( harden plastic)
Here is a link to a pic http://www.westmarine.com/oil-change...1-1-4--6586085. It looks strong but it has check valve for the fresh water flush and a check valve for cracking pressure on the inlet side to the sea pump. It seems to work well, but I bought the boat with it. I am on the fence with this unit but have not seen and bad comments regarding it. SO maybe I should change this system out and use a manual valve as you are suggesting. Your thoughts? |
(Post 4087271)
I have the original Groco SA series strainers that came with my Fountain in 1990. Still working fine, and fully serviceable. Not very blingy, but they work
(Post 4087160)
| All times are GMT -5. The time now is 07:20 AM. |
