-   -   looking for procharger guru's (https://www.offshoreonly.com/forums/general-q/309767-looking-procharger-gurus.html)
hangem out 2dry 03-17-2014 09:25 AM
setting up some m3 prochargers on 540's. looking for advice . dart heads 9.5 comp low boost 5lb. plugs heat range gap,timing ect.
what is your setup?taking suggestions
throttleman 03-17-2014 09:35 AM
just finished a m3 on a 555ci , are you goint to is a carb or efi ? throttleman
hangem out 2dry 03-17-2014 10:04 AM
carb blow thru csu with a hat
kennyo 03-17-2014 12:53 PM
There is a ton of info in the search feature...MOst has to do with efi but you should find what you need...I know a dyno is almost a must to get an efi right....
hangem out 2dry 03-18-2014 06:16 AM
bump
airjunky 03-18-2014 08:19 AM
Orig 540 procharger set up used a gravity feed oil feed and drain boost referenced fuel feed Mr43t or 1 step colder plugs ..I have the orig install manual and some extra brackets
ezstriper 03-19-2014 08:34 AM
Run a M3 on a 509, when running a carb had prosystems do a 950 for me was spot on out of the box, ran the procharger box, Patrick did not like the idea of me running a hat, and they are NOT legal on a boat, now running our own port EFI and that is the way to go hands down..as far as tuning, if you do not have a carb done for the app, jet pretty rich to start, have to boost reference the power valve in primary, don't run one in the secondary, make sure you have solid floats(not brass) as they will crush, I run a aeromotive A1000 pump large line and a boost referenced regulator with a RETURN(very important) locked dist at about 28 timing..good luck Rob
hangem out 2dry 03-19-2014 05:28 PM
rob thanks for the info how much boost are you running?I had kevin at csu build my carbs for hats ,.
MILD THUNDER 03-19-2014 07:48 PM
I'd run a plug at least a couple steps colder than a delco 43. Thats a stock mercury naturally aspirated plug. I'd run a NGK -9, or even a 10. And NON projected tip. Boost referenced regulator with a return to the tank.
lightning jet 03-19-2014 08:12 PM
Return to tank or through a cooler back to front of pump this works better in a single with twin tanks ......good luck
hangem out 2dry 03-20-2014 06:42 AM
Thanks for the info guys keep it coming every little bit helps.what about some timing numbers
