-   -   Wiring diagram needed (https://www.offshoreonly.com/forums/general-q/309917-wiring-diagram-needed.html)
fastestonehere 03-20-2014 07:50 PM
Mercruiser 14 pin diagram or pin out needed. Wiring a 496Ho and having trouble with start solenoid not working from harness
Need engine side 14 pin wiring pin out diagram
fastestonehere 03-22-2014 08:50 AM
Found the issue with start solenoid. The 16 pin (I think) connector on top motor. It has two black wire that need to be connected together to ground start relay..
Also I ran it on the shipping crate for about 1/2 hour ran great wated fuel presure higher so I upped it 3# and ran fine real responsive. Here a little idle video. Raylar 102 cam roller rockers light head porting and bowl work adj. fuel pres. regulator and whipple remapped ECU.
http://youtu.be/SPyW_sfJcgs
