Pin out sheet needed mefi 1 to mefi 4
Looking for pin out diagram for bbc changing from mefi 1 to mefi 4.
Ttt
Originally Posted by asb929
(Post 4094000)
I have the pinout if you need it. However, be prepared for a time consuming job. It is a real pain. It's not bad going from a 3 to a 4, but from a 1/2 to a 4 sucks. A good bit of the wires need to swap J plugs, so some will end up being way to long, and others will need to be lengthened by quite a bit. I've done a few in the past and said I would never do it again. You are dealing with a harness that is probably near 20 years old. They get brittle, stiff and just hard to work with in general.
Let me know if you want the pin out. Or, I can build you a new custom harness that will fit like a glove, is all brand new and has a braided nylon covering instead of 3 rolls of electrical tape. Eddie |
Originally Posted by Young Performance
(Post 4094960)
Eddie how much do you charge for a new harness,i think that is really the only right way of doing it
Thanks for the info Eddie. I will contact you by phone for a new harness.
| All times are GMT -5. The time now is 03:10 PM. |
