-   -   Mounting sea strainer (https://www.offshoreonly.com/forums/general-q/310182-mounting-sea-strainer.html)
Priobe 03-26-2014 09:25 PM
Hello all
This is on a formula 252
I am a little concern when mounting the sea strainer. The best place I found to mount it on the area where the battery is mounted to the floor. I am using the Teague sea strainer with the floor mount bracket. Is ok to screw straight down.
Also can if possible can you guys show me where you mounted yours so can get some ideas
In case you have not notice I'm a first time boat owner
HyFive578 03-26-2014 09:32 PM
You're better off mounting it to a stringer and through bolting if possible. The screws used to mount the battery are usually 1" or less long. I would avoid screwing it to the bottom of the boat if at all possible.
Black Baja 03-26-2014 10:57 PM
Originally Posted by Priobe (Post 4096538)
Hello all
You are talking about the floor and not the bottom of the hull?
Randy Nielsen 03-27-2014 12:31 AM
2 Attachment(s)
[ATTACH=CONFIG]521047[/ATTACH][ATTACH=CONFIG]521046[/ATTACH]Here is where I mounted mine & how I plumbed them. They work great, have not had any issues pulling water up to them & they are easy to inspect and or clean. I now have the correct color tops so that will be changed this year, Lol. Randy
pstorti 03-28-2014 07:04 AM
mount them so the lid is just above your waterline, that way you can clean them when the boat is in the water, and you can stick a hose in there to flush the motors even in the water.
Gimme Fuel 03-28-2014 08:21 AM
Is it better to plumb them before (under vaccuum) or ofter the sea pump (under pressure)?
pstorti 03-28-2014 01:05 PM
the purpose of a sea strainer is to prevent debris from getting into the pump and engine, so before.
Priobe 03-28-2014 02:03 PM
Yes the area that I am looking to mount the strainer is on the floor where the battery is mounted not the hull floor.
Also, I was thinking of laying down some star board first the screwing the strainer to the starboard . I would secure the starboard to the floor with screws and silicone
Is this necessary?or over kill
dereknkathy 03-28-2014 05:11 PM
as pstorti said. lids above waterline. MUST be above waterline. if below waterline and u hafta open them or one, water comes into boat. fast. but come to think of it, it is a real quick way to clean out the strainers...
Priobe 03-28-2014 05:51 PM
Yea but if I install a ball valve can't I just close the valve?
