-   -   What fuel would your run (https://www.offshoreonly.com/forums/general-q/310699-what-fuel-would-your-run.html)
hangem out 2dry 04-08-2014 08:15 AM
If you had to make a choice what fuel would you run on a boost application 540 procharger with 5 to 7 lb of boost. 91 octane no ethanol or 93 with ethanol.
mike tkach 04-08-2014 08:31 AM
as much as i hate ethanol i hate detonation worse,i would use the 93.
inspector747 04-08-2014 08:57 AM
Do they not offer 93 without Ethanol where you live?
hangem out 2dry 04-08-2014 09:29 AM
no they sure dont
Eliminated572 04-08-2014 09:35 AM
Surprisingly I have never had an ethanol related problem yet. Have a few hot rods not driven often and of course the boat. Try to at least start up fairly often and always run stabil thru everything before winter storage so it enters carbs ect...I run the tanks down to about 1/4 before winter... Been running 93 w/ 10%ethanol (Our only choice in 93. Try to avoid 91)
inspector747 04-08-2014 10:12 AM
Originally Posted by hangem out 2dry (Post 4103174)
no they sure dont
Only reason I asked was there a few stations in LA that have 93 Ethanol free. I'm sure there is a link on this site somewhere but here it is just in case
http://pure-gas.org/
hullofjustis 04-08-2014 10:29 AM
I think i would run non ethanol and use octane booster or 5 gallons or so of race fuel,. I despize ethanol fuel.
Ior i would put a exhaust temp sensor in my manifolds.
skydog 04-08-2014 10:51 AM
inner cooler? Steel heads?
hangem out 2dry 04-08-2014 11:18 AM
inner cooler aluminum heads
skydog 04-08-2014 11:43 AM
Nice set-up, 93 would be my pick too. Whats your CR? Does it have a big cam? Or average hydraulic?
