-   -   Newbie question bravo steering actuator (https://www.offshoreonly.com/forums/general-q/310902-newbie-question-bravo-steering-actuator.html)
kingerf8 04-13-2014 10:58 AM
Engine#OC878753
Tra ns#OD369170
Drive#OF343734
My power steering actuator is leaking.Part#no longer available.Have read info on updated parts but can not figure out what is needed.Some say p/s lines must be replaced.Is there a kit that comes with hoses and actuator?Found part#'s806034A2,8M0063381 BUT CONFUSED ON WHICH ONE TO GET.
THANKS
smokin' gun 04-13-2014 11:10 AM
What year boat there is 2 styles Saginaw and Brazil early style is Saginaw later style is Brazil all aluminum I have some of both if you need them
kingerf8 04-13-2014 11:30 AM
1990 Baha
ezstriper 04-14-2014 04:10 PM
simple swap, find one of the later units(ebay lots of times) you will need to change the lines to O-ring style, just order later model ones, you should already have the O-ring on the pump end, my 89 did, if it does not you can change out that fitting easily, just keep the pressure relive valve and spring that is right under the fitting...you also will loose the 2 short lines at the cyl you have now...newer setup much better....also look to see if somebody changed to full Hyd and has what you need...
kingerf8 04-14-2014 07:36 PM
Thanks for reply ez.the search is on lol
Borgie 04-14-2014 11:08 PM
I have a low hour unit old design if interested.
Budman II 04-15-2014 09:47 AM
Also, look closely at you lines to make sure that they are not leaking. I was certain that mine was bad a couple years ago, went to the trouble to replace it, and then when I hooked it back up found that I had a cut in one of the lines that was spewing fluid in the direction of the actuator, which made it look just like it was the actuator leaking.
dereknkathy 04-16-2014 07:26 AM
the 2 short metal lines have rusted out. i got short copper lines from auto parts store and bent them up and installed them. hardest part was getting valve out of boat, which you hafta do whether you are checking it out or replacing anyway.
ezstriper 04-16-2014 08:45 AM
if you upgrade to the newer style they do not use the short lines anymore...
35fountain 04-17-2014 06:34 AM
Mine was leaking also. Saginaw. I bought this used on ebay .replaced it no more leak..
http://www.ebay.com/itm/MERCRUISER-P...c98ff6&vxp=mtr
