Use "The Right Stuff" in place of circ pump & t-stat gaskets?
Was dressing out my engine, and realized that I had misplaced my water pump (circ pump) and thermostat housing gaskets. Also need one for the fuel pump blockoff plate. I have heard a lot of people say the the Permatex product "The Right Stuff" is the catz azz in gasket makers, and was wondering if I can get away with just using this stuff in place of the aforementioned gaskets. Anyone done this with success?
i dont make a habbit of subing the right stuff for gaskets but i have done it in a pinch with no leaks.i do use it in place of the end gaskets on bbc intake manifolds and never had one leak.the right stuff is the right stuff.
btw budman,the right stuff is a sealer not a gasket maker but it works good for both imo.
Originally Posted by mike tkach
(Post 4106236)
BTW, had a weird issue with my temp gauge not working years ago. Thought I had a bad gauge, then after some investigation realized that I had used an automotive T-stat gasket instead of the Merc version that had the little metal conducter rings in it to establish a ground to the senders in the T-stat housing. One of those little "gotcha's". |
| All times are GMT -5. The time now is 02:19 PM. |
