-   -   Imco end cap (https://www.offshoreonly.com/forums/general-q/31138-imco-end-cap.html)
BigJake 08-17-2002 07:43 PM
Imco end cap
I just replaced a bravo 1 drive but I need to know. How i go about drilling out and tapping the two holes for the imco end cap. I purchased the boat used and it came with the IMCO stearing all ready on. need help Thanks :confused:
Cord 08-17-2002 07:49 PM
Imco makes a jig for this task.
BigJake 08-17-2002 08:13 PM
I saw the jig on there website but i hoped there was a way of doing it with out buying the the jig at $165.00. If any one knows another way. thanks
dlbCheckmate 08-17-2002 09:46 PM
I bought and installed a new Imco system on my Bravo. I saved the distructions (:D :D :D )
" STEP 1 INSTALL THE FIVE BOLT END CAP ( using step drill or drill jig)
1. Drain approximately one quart of oil from drive using clean container.
2. Remove the Bravo end cap and tape over opening leaving the three holes clear.
3. Are you using a step drill or drill jig ?
a. If you are using a step drill: Bolt on the new end cap and drill the two holes 1" deep using the step drill provided in the kit, use W_D 40 to help drill the holes. (do not install the o-rings in the cap at this point.) Remove end cap and tap two holes with a 3/8-16 bottom tap, using tap oil for a clean thread.
b. If you are using drill jig : yada, yada, same instructions....
You need to get a step drill, 25/64 ths step to 5/16 ths.
Hope this helps
BigJake 08-17-2002 09:58 PM
YOUR THE MAN Just what I was looking for.
pachangalpina 08-19-2002 10:39 AM
I still have the step drill and instructions that came with mine if anybody needs them.
Todd Howerton
Outlaw Performance Products
770-844-1777
