-   -   formula f302 bravo conversation (https://www.offshoreonly.com/forums/general-q/311497-formula-f302-bravo-conversation.html)
Trouble boy 04-27-2014 07:11 AM
Has anyone did this. Trs to bravo. Did u move motors back or use driveshafts? I know about K on rads not going that route. I called formula but there no help
dereknkathy 04-27-2014 10:20 AM
it is a heavy boat. moving motors back adds to weight in the stern. taking out transmissions and TRS's removes weight in the stern. running shafts to leave motors forward will double the price of the install. you can get bravo gimballs for a nickel and drives for 1k. jackshafts are exotic and hard to find. usually hafta be made up for the application. if you're gonna do it, standard bravo mount at the transom is the way to go. replacing the transom is the hardest part. best bet is to buy more used TRS stuff and run it...
