Where can I get exhaust block off plate
My boat has captains choice and won't work with my headers so I was going to take the y pipe off. Where can I get a block off plate for it for bravo 1 outdrive? If from marina does anyone have part #
Originally Posted by Cole2534
(Post 4124594)
CP performance makes really nice ones were you can leave the Y pipe in. I have a used set $30.00 shipped cont. US
Originally Posted by Expensive Date
(Post 4124667)
I have the exact one listed
http://www.keitheickert.com/p-13860-...lications.aspx You have to pull the y-pipe to install it. It bolts to the inner transom plate to block the exhaust exit under water. |
1 Attachment(s)
[ATTACH=CONFIG]523602[/ATTACH] No these you use the rubber coupler, they go inside the coupler.
engine has to come out for anything but expendate's setup. then just get 3 feet of hose cut in half to run where diverters were.
I did the el cheapo redneck solution to the problem - similar to what Expensive Date has. Went to Lowes and got some rubber plugs in the plumbing department, installed them in the rubber boots with some Right Stuff to seal them up. Ran some stainless screws through them for insurance that they couldn't pop out. Ran two years like this without leaking a drop. Planning to put SC back on, so it was a temporary solution, but it worked fine.
| All times are GMT -5. The time now is 10:08 AM. |
