-   -   2.5 Merc outboards (https://www.offshoreonly.com/forums/general-q/31272-2-5-merc-outboards.html)
yahoo 08-19-2002 08:53 PM
2.5 Merc outboards
I just purchased my first outboard boat. What is the mixture ?
Is their a rev limiter ?
Is it fact or fiction on the stopping the motor to shift ?
What maintenance do they need ?
Team Yahoo
Curtis
mopower 08-19-2002 09:19 PM
Back in the last 50's / early 60's Mercury made an outboard with NO neutral or reverse:eek: :eek: Neutral equated to 'Shut it off and reverse was (believe or don't) start the engine bacwards.
Since 2 cycles will run in either direction , the starter was set up to go either way. It was a royal pain in the a$$ and didn't go over to good. OMC loved it , but Merc. soon saw the error of their ways and went back to a standard shift type engine:rolleyes:
Audiofn 08-20-2002 02:06 AM
Yahoo now that you got your history lesson on the "dock basher" motors I will have to get more info on your engine to know what you are looking for. I assume you mean the oil mix ratio. Are your motors 2.5 displacement engines or 2.5efi offshore motors? If they are stock 2.5 displacement engines then you mix 50:1. We ran our 2.5efi offshore race motors at 30:1. If you need any more info let me know
Jon
yahoo 08-20-2002 07:18 AM
They are 2.5 efit 280hp, 1998 motors.
We mixed the gas at 40-:1 by mistake and it smoked pretty bad, keep the mosquitos away.
Curtis
Audiofn 08-20-2002 11:43 AM
Oh ya those motors will smoke. That is good it lets you know you are getting enough lube in there. Go 30:1 with it and use a very high end oil. DO NOT cheap out. If you go to www.Screamandfly.com there is a lot more outboard info there for you. I think that Pennzoil and there is another smoke a lot less then the merc stuff.
Jon
