ham_r_down01 |
05-24-2014 01:53 PM |
Comp cams 212 Timing cover
:picard1: Has anyone used one of these with their standard water pump on a Mark4 454? Mine is fighting every step of the way. I have a short style pump I think..?? I know small blocks have a short and long style.
Problem is, its hitting the cover, the legs that go to the block. It says in the destructions to grind the pump to make room. Has anyone else had this problem? I installed the supplied allen bolts that make room for the bolt clearance problem, but the outlets dont mate up to the block anyways.
http://static.summitracing.com/globa.../cca-212_w.jpg
