-   -   Engine rotation (https://www.offshoreonly.com/forums/general-q/312758-engine-rotation.html)
kwtv38 05-24-2014 04:37 PM
Engine rotation
I have a 1998 7.4 mercruiser Bravo1 long story short I'm installing a new raw water pump and can't figure what way the impeller fins need to go. Not sure what rotation my engine is either and serial # is worn off... Any help would be so appreciated
rrentsch 05-24-2014 04:52 PM
1 Attachment(s)
With the plastic housing in your left hand. Twist the impeller into the housing clockwise. put the impeller on the shaft of the belt pulley, soap it up and twist in holding on to the belt pulley
Black Baja 05-24-2014 04:55 PM
Crank the motor over with the starter the should give you a good idea.
kwtv38 05-24-2014 05:09 PM
That's not possible Right now
motor 05-24-2014 05:36 PM
Standard engine is left hand as viewed from the flywheel end..
Young Performance 05-25-2014 12:27 AM
Typical engine is left hand rotation. Look at the rear of the impeller housing. It will show the direction of rotation for both left hand and right hand rotations.
Eddie
ezstriper 05-25-2014 09:21 AM
won't really matter, when you spin it over will go to right direction, make sure you lube well, and make sure you don't cross the hoses, that makes big difference..
