-   -   330hp to 350hp vortec 454 (https://www.offshoreonly.com/forums/general-q/313086-330hp-350hp-vortec-454-a.html)
Novaspd 05-31-2014 01:23 PM
Nasty rod knock developed over last weekend. Tore it down found the crank is trashed,block is already bored .40 over so I don't want to put any money into a beat block so I went with a 350hp vortec motor. Now I'm wondering what, if any problems will I run into rigging the 350hp long block with all my 330hp non vortec motor accessories. Anyone done this swap? Off the top of my head all I can think is new intake possibly bigger carb??
I've re read my post and realized it doesn't make much sense. Basically I'm going from the gen 5 330hp non vortec 454 to the gen 6 350hp vortec 454. Long block only. I'm wondering if all the brackets and accessories are just a bolt on affair or if other parts will be needed?
Novaspd 06-01-2014 03:08 PM
Edit
Budman II 06-01-2014 04:54 PM
Is the engine you are installing an automitive or truck engine, or is it marine? All of the accessories like circ pump, alt, seawater pump, starter, etc. should swap over from your old engine. Intake and carb should swap over fine as well. The main thing you need to watch out for is the oil bypass valve that is installed in the filter pad on Gen VI engines. Car and truck applications usually got an 11 lb bypass, and this needs to be replaced with a 30 lb bypass for a boat engine due to the extra pressure generated by the remote oil filter and oil cooler. Leave the original bypass in there and you will bypass your filter and cooler and send hot dirty oil through your bearings, and you will be on here talking about your next engine. Do a search on this forum for "oil bypass" and you will turn up some threads that discuss this and list the part number you will need.
Novaspd 06-01-2014 05:45 PM
Thanks for the reply, a lot of useful info there. The long block is from advanced marine out of Casper, Wyoming. It's just advertised as 96+ vortec 454. Being from a marine rebuilder id hope they would have the proper by pass installed. I'll do some research and find out how to check it tho. Anyone had any experience with this engine rebuilder???
Borgie 06-01-2014 06:18 PM
Here is the thread Budman is referencing:
http://www.offshoreonly.com/forums/g...-hardware.html
The bypass valve is cheap and east to replace, however there are two. You will see that there are two schools of thought when running a oil thermostat and cooler, wether to leave the one bypass in place or plug it.
