the bypass relief spring just opens and oil bypasses the filter cooler with the stock stuff, 1/2" is #10 I used aeroquip twist lines
borgie my pressure on a stock 502 mag ranges from 20 -40 should I make this modification?
Originally Posted by Wes Burmark
(Post 4131790)
Thanks BORGIE
The new coolers are set up for 1/2" pipe plug. I'm not sure if that would be 8AN or 10AN lines. I will be looking into a block and remote filter adapters that will accept larger lines. If someone has used a particular brand I would would love to hear about it. Block adapter: http://teaguecustommarine.com/smartt...off-gen-v.html Filter mount: http://teaguecustommarine.com/smartt...-npt-left.html I also am using the Teague billet fuel filter mount for the FST brand fuel filter. FST is one of the best, so keep that in mind if you eventually upgrade your fuel system. |
Originally Posted by stimleck
(Post 4149137)
| All times are GMT -5. The time now is 06:24 PM. |
