Replacing 555 on 496 with MEFI Controller
Anyone out there done this?
And I can't find enough reading to determine whether or not the 4 can do digital tach? The harness is easy. Got that already. Just looking to see what MEFI has worked best for you 4, 4a, 4b or 5? Thanks! |
Have you made any progress? I know the 4s will run crank fired ignition like your 496 has.
Tyler Crockett did this on quite a few, I believe he used mefi4'bs, Smitty
Have you looked into the Holley HP EFI systems? I'm running one on my 565 with crank fired ignition and coil packs. Alex Haxby has a very nice thread going on the system.
I have done it.... I used MEFI4B's and got rid of the 555 so i could adjust and the program when i put whipples on them .... the volvo penta version of the 49HO used the MEFI4B also
I switched from the MEFI one to Holley HP. Couldn't be happier.
The HP is much easier for a rookie tuner like me, when compared to the MEFI. |
have to ask digital tach meaning smartcraft or something else. Smartcraft only relates to ECM / PCM 555. Also I do not think MEFI 4/a will work because the 496 is distributorless has cam and crank sensor. I am sure MEFI 4b and 5 and 6 will work for a 496. I could be wrong about MEFI 4/a but again I do know 4b will work for the 496.
I have seen MEFI 4 done with a digital display but it was a whole display. Also I know Boostpower has done it as well with digital display gauges as a whole unit. Want to say he used MEFI 3 or 4 if I remember correctly. Neither one was from a 496 app. |
| All times are GMT -5. The time now is 03:33 PM. |
